Hello Guest it is November 13, 2026, 12:31:34 PM
Author Topic: RijK words all missing  (Read 10201 times)
« on: August 24, 2017, 05:29:27 AM »
Hi all.
I am a newbie  I did search the site but found nothing relevant. So please bear with me.
I am running mach3 on an XP system. On some G code files, (not all), containing curves I get an error message
RijK words all missing arclinexx.
 xx varies file to file. And Mach3 obviously  does not display the paths or run the file.
Have I something wrongly set in Mach3 setup or is it just a G code creation error of some sort.
Rick
Re: RijK words all missing
« Reply #1 on: August 24, 2017, 05:36:11 AM »
It's an error with your g-code.
« Reply #2 on: August 24, 2017, 09:01:07 AM »
Thanks Gerry.
I was pretty sure that was the reason as the G-code generated by another CAM package from the same DXF did not demonstrate the problem.
I just wanted to be sure it was not my setup.
Rick
