Mach Discussion => General Mach Discussion => Topic started by: rick2017 on August 24, 2017, 06:29:27 AM
Hi all.
I am a newbie I did search the site but found nothing relevant. So please bear with me.
I am running mach3 on an XP system. On some G code files, (not all), containing curves I get an error message
RijK words all missing arclinexx.
xx varies file to file. And Mach3 obviously does not display the paths or run the file.
Have I something wrongly set in Mach3 setup or is it just a G code creation error of some sort.
Rick
It's an error with your g-code.
Thanks Gerry.
I was pretty sure that was the reason as the G-code generated by another CAM package from the same DXF did not demonstrate the problem.
I just wanted to be sure it was not my setup.
Rick
