Hello
Guest
it is
October 24, 2026, 11:16:52 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Strange rotary toolpath.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Strange rotary toolpath. (Read 10265 times)
Hazeldene
4
on:
July 02, 2017, 04:50:40 PM »
Hi all, I've been using vcarve pro to produce rotary toolpaths, something's obviously not right in my setting's but I can't figure out what, if anyone can help me out I'd be grateful
Here are some pics, one is a preview in vcarve, the other is the toolpath in mach, thanks.
Si
Tweakie.CNC
9,374
Super Kitty
Re: Strange rotary toolpath.
Reply #1 on:
July 03, 2017, 12:52:31 AM »
Check your generated Gcode - Does it contain a G90.1 or a G91.1 at the beginning ?
If it does not then change the IJ Mode in General Config. and then regen. toolpath.
Hazeldene
4
Reply #2 on:
July 03, 2017, 02:56:15 AM »
Thanks Tweakie, will try that later and let you know
Hazeldene
4
Reply #3 on:
July 03, 2017, 11:39:46 AM »
Hi Tweakie, yes it Doe's contain G91.1, tried changing ij and regenning, sadly no difference, do you think it might be a Vectric issue ?
Si
Hazeldene
4
Reply #4 on:
July 03, 2017, 12:16:25 PM »
Actually, don't worry, I figured it out. In "Rotational" I unchecked "Rot 360 Rollover" .that did the trick
Thanks for your help though.
Regards
Si
Tweakie.CNC
9,374
Super Kitty
Reply #5 on:
July 04, 2017, 12:47:35 AM »
Excellent news, I am pleased you have found the problem.
Print
Pages:
1
Go Up
« previous
next »
