Hello
Guest
it is
November 13, 2026, 09:40:08 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Change from parallel to ESS SmoothStepper
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Change from parallel to ESS SmoothStepper (Read 28840 times)
Tweakie.CNC
9,377
Super Kitty
Re: Change from parallel to ESS SmoothStepper
Reply #10 on:
May 07, 2017, 02:55:02 AM »
Another question:
If you use the keyboard left / right arrow keys to jog the axis does it move at 45° ?
Burgy22
12
Reply #11 on:
May 07, 2017, 03:12:22 AM »
infomation that might help.i stand to the side of my mill always have done up til now without any problems, i.e what i see on the Display is what i get on the table looking from the side.
i use an xbox joypad for jogging.
Steve
Tweakie.CNC
9,377
Super Kitty
Reply #12 on:
May 07, 2017, 03:24:58 AM »
So your work is rotated 90° to the display not 45° ?
Burgy22
12
Reply #13 on:
May 07, 2017, 03:38:46 AM »
here an example:
Display --> shows Tree standing up.
Mill (Looking from my position on the left) --> mills tree lying on it left.
Before my change from parallel to ESS it was.
Mill (Looking from my position on the left) --> mills tree standing up.
Steve
Burgy22
12
Reply #14 on:
May 07, 2017, 03:43:18 AM »
Yes your right 90°
Sorry
Steve
Tweakie.CNC
9,377
Super Kitty
Reply #15 on:
May 07, 2017, 03:45:26 AM »
Hi Steve,
No problem
The actual layout of the X and Y axes usually depends on where the operator stands in relation to the machine (A Mill, for example, may be configured differently to a Router).
You should change your axes (port and pin configuration) so that the direction that the cutter moves in relation to the work piece should always be as shown in this diagram.
Burgy22
12
Reply #16 on:
May 07, 2017, 03:46:37 AM »
Where can i change this?
Steve
Burgy22
12
Reply #17 on:
May 07, 2017, 03:47:46 AM »
And how?
I tried swapping x&y the result was a 180° turn.
Steve
Last Edit: May 07, 2017, 03:52:03 AM by Burgy22
Tweakie.CNC
9,377
Super Kitty
Reply #18 on:
May 07, 2017, 04:18:52 AM »
Config. / Ports & Pins / Motor Outputs.
Swap your X axis Step Pin# and Dir Pin# with your Y axis Step Pin# and Dir Pin#
If any axis then drives in the wrong direction (see earlier diagram) change the Dir Low Active state for that axis.
Burgy22
12
Reply #19 on:
May 07, 2017, 05:08:12 AM »
Tweakie thank you for your patience it worked.
just did my first Routing with the new Stepper, the result is ok just a "little" small, the proportions are correct.
Steve
Print
Pages:
1
2
3
Go Up
« previous
next »
