Hello Guest it is November 13, 2026, 09:31:14 PM
Author Topic: Change from parallel to ESS SmoothStepper  (Read 28827 times)
  •  9,377 9,377
Re: Change from parallel to ESS SmoothStepper
« Reply #10 on: May 07, 2017, 02:55:02 AM »
Another question:
If you use the keyboard left / right arrow keys to jog the axis does it move at 45° ?
« Reply #11 on: May 07, 2017, 03:12:22 AM »
infomation that might help.i stand to the side of my mill always have done up til now without any problems, i.e what i see on the Display is what i get on the table looking from the side.
i use an xbox joypad for jogging.
Steve
  •  9,377 9,377
« Reply #12 on: May 07, 2017, 03:24:58 AM »
So your work is rotated 90° to the display not 45° ?
« Reply #13 on: May 07, 2017, 03:38:46 AM »
here an example:
Display --> shows Tree standing up.
Mill (Looking from my position on the left) --> mills tree lying on it left.
Before my change from parallel to ESS it was.
Mill (Looking from my position on the left) --> mills tree standing up.
Steve
« Reply #14 on: May 07, 2017, 03:43:18 AM »
Yes your right 90°
Sorry
Steve
  •  9,377 9,377
« Reply #15 on: May 07, 2017, 03:45:26 AM »
Hi Steve,
No problem  :)
The actual layout of the X and Y axes usually depends on where the operator stands in relation to the machine (A Mill, for example, may be configured differently to a Router).
You should change your axes (port and pin configuration) so that the direction that the cutter moves in relation to the work piece should always be as shown in this diagram.
« Reply #16 on: May 07, 2017, 03:46:37 AM »
Where can i change this?
Steve
« Reply #17 on: May 07, 2017, 03:47:46 AM »
And how?
I tried swapping x&y the result was a 180° turn.
Steve
« Last Edit: May 07, 2017, 03:52:03 AM by Burgy22 »
  •  9,377 9,377
« Reply #18 on: May 07, 2017, 04:18:52 AM »
Config. / Ports & Pins / Motor Outputs.
Swap your X axis Step Pin# and Dir Pin# with your Y axis Step Pin# and Dir Pin#
If any axis then drives in the wrong direction (see earlier diagram) change the Dir Low Active state for that axis.
« Reply #19 on: May 07, 2017, 05:08:12 AM »
Tweakie thank you for your patience it worked.
just did my first Routing with the new Stepper, the result is ok just a "little" small, the proportions are correct.
Steve
