Hello
Guest
it is
November 23, 2026, 11:07:51 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
trouble hooking up run/stop/zerox, y, z buttons
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: trouble hooking up run/stop/zerox, y, z buttons (Read 12534 times)
mbwittig
on:
June 19, 2007, 01:59:21 PM »
I've got the buttons installed on a panel on my machine and I've run wires to the parallel port input pins with the 470 ohm resistors like the docs say. I dont know how to make them push the buttons on the screen though. How do I link pins to pushing screen buttons like "run" "stop" and "zero x" ?
Thanks!
-Mike
Logged
Chaoticone
5,624
Precision Chaos
Re: trouble hooking up run/stop/zerox, y, z buttons
Reply #1 on:
June 19, 2007, 02:33:30 PM »
Hey Mike,
You can set them up as triggers in ports and pins, inputs. Then go to config, system hotkeys and assign them an OEM code. I hope the pics help.
Logged
If you could see the things I have in my head, you would be laughing too.
mbwittig
Reply #2 on:
June 19, 2007, 04:33:34 PM »
where do I get the codes from for each button on the display?
Logged
Chaoticone
5,624
Precision Chaos
Reply #3 on:
June 19, 2007, 05:51:20 PM »
I think most of them are listed in the wiki.
http://www.artsoftcontrols.com/MachCustomizeWiki/index.php?title=Main_Page
Go down to section 9, OEM buttons.
Logged
Print
Pages:
1
Go Up
« previous
next »
