Hello Guest it is November 12, 2026, 04:47:02 PM
Author Topic: Mach3 reads in cm and not in mm in Gcode file...  (Read 58307 times)
  •  9,377 9,377
Re: Mach3 reads in cm and not in mm in Gcode file...
« Reply #21 on: March 15, 2018, 05:25:23 AM »
I have no idea what is best, I just use WinXP on a 32 bit PC.
That Dell Optiplex looks just fine to me (but I have never used one so cannot say one way or the other).
Offline TPS
  •  2,627 2,627
« Reply #22 on: March 15, 2018, 05:42:36 AM »
i would start with
-a fresh install of M3
-a new blanc Profile
and do the steup (manually) again, takes maybe half a hour.
there is no reason that it should not run on a 32Bit Win7
just a thought.
« Reply #23 on: March 15, 2018, 05:54:29 AM »
OK thanks Tweakie,
I will try to clean the PC as much as I can then a fresh install of M3 and a manual setup, I have my notes.
I will do this on my 64BIT PC running WIN7
and then I will report back...
thanks for the help and advice  :)
« Reply #24 on: March 15, 2018, 06:20:58 AM »
You may have a problem with the Dell OptiPlex.  Most of the ones I have tried to use  had bad pulse signals
and the pulse rates really varied for the PP .  May need to use an external motion device.
My experience with them, and as usual, your 's may turn out to be different!
« Reply #25 on: March 15, 2018, 07:39:47 AM »
Thanks RICH.
« Reply #26 on: March 15, 2018, 09:16:09 AM »
OK so I tried a new install of MACH3 and I did not add the old xml file.
When I clicked on MACH3 to open it to begin configuration the pc crashed!!!   >:(  :(  :o  ???  :'(
I can open every other program on the PC except MACH3. :)
Unless anyone has a better suggestion I think it is time to reload the PC back to 'factory fresh' and then start again.... ???  ???  ???
Offline TPS
  •  2,627 2,627
« Reply #27 on: March 15, 2018, 09:39:37 AM »
are you starting Mach3 as Admin ?
« Reply #28 on: March 15, 2018, 10:15:01 AM »
I haven't since I set this machine up, should that make a difference?
Offline TPS
  •  2,627 2,627
« Reply #29 on: March 15, 2018, 10:59:30 AM »
maybe, who knows.
