Hello Guest it is November 19, 2026, 03:56:41 AM
Author Topic: Mach3 safety switch wiring  (Read 9275 times)
« on: February 22, 2017, 07:55:31 PM »
I am using a N/O switch. One leg connected ground other leg connected to pin input pin 2.  Just. Testing one switch nothing happens.
Have inport pin one and pin is #2.   Active low.  Please advise where I am going wrong.
Thank you
Offline Davek0974
  •  2,606 2,606
Re: Mach3 safety switch wiring
« Reply #1 on: February 23, 2017, 01:10:35 AM »
Does your BOB work that way or does it need say one pin to 5v and the other to the input - pull up or pull down
« Reply #2 on: February 23, 2017, 05:58:13 AM »
Do not know what BOB means.
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: February 23, 2017, 06:17:57 AM »
Apologies, BOB = Break Out Board = the board that connects your inputs / outputs to your PC
« Reply #4 on: February 23, 2017, 08:47:16 AM »
For some reason I am unable to upload imiges.
