Hello Guest it is September 06, 2026, 12:47:15 AM
Author Topic: Laptop DB25 parallel port ?  (Read 10306 times)
« on: February 05, 2017, 01:39:38 PM »
Is there a way to get a laptop that does not have a parallel port only USB ports, to run Mach3 using the parallel port on my C10 BOB?
OK this may be a dumb question but I'm getting desperate to get some installation to work.........................
« Last Edit: February 05, 2017, 01:42:06 PM by gene8522 »
Offline kolias
  •  1,165 1,165
Re: Laptop DB25 parallel port ?
« Reply #1 on: February 05, 2017, 02:14:41 PM »
Laptops in general no recommended to run Mach3 due to the lower voltage they run and witout a paraller port no way. But I think there is warp or smoothstepper which connect to a usb but I'm not familiar with that. Google Mach3 usb
Nicolas
« Reply #2 on: February 05, 2017, 02:15:48 PM »
Yes, with a UC100 motion controller.
« Reply #3 on: February 05, 2017, 03:33:06 PM »
Thank Garry I thought that that would be the answer I would get. Will the UC100 work on a 64 bit PC?
« Reply #4 on: February 05, 2017, 04:07:19 PM »
Yes
