Hello
Guest
it is
November 19, 2026, 06:06:49 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
DFX to G Code
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: DFX to G Code (Read 43985 times)
toppcatt22
DFX to G Code
on:
June 12, 2007, 01:14:39 PM »
I have a 3-D wireframe turboCAD drawing as well as the .DXF that I want to convert to a G code. So far no luck but I have yet to purchase the product, is this why I am experiencing troubles? Also, does mach3 do the 3D stimulation?
Graham Waterworth
2,785
Yorkshire Dales, England
Re: DFX to G Code
Reply #1 on:
June 17, 2007, 06:05:49 PM »
You will have to drop the file into a 3d CAM system and generate the code, then mach will run the code.
Graham.
Nick@Artsoft
2
Re: DFX to G Code
Reply #2 on:
July 20, 2007, 02:17:12 AM »
I'm basically needing to do the same thing. I need to convert a dxf file into gcode. Any suggestions of what software? Nick.
Graham Waterworth
2,785
Re: DFX to G Code
Reply #3 on:
July 20, 2007, 08:55:57 AM »
LazyCAM Pro will do the 2D/2.5D stuff, if your budget stretches into 1000,s then look at AlphaCAM, OneCNC, MasterCAM, BobCAD/CAM, Etc.
Graham.
frankg521
9
Re: DFX to G Code
Reply #4 on:
August 06, 2007, 08:12:36 PM »
Hi I have access to master cam any tutorials on how to do this I can use the computer with master cam if I take the files I make with me
dmai
3
Re: DFX to G Code
Reply #5 on:
December 20, 2007, 08:34:43 PM »
I'm looking into getting a cnc engraver, working to turn rhino 3d files into 3d models. The chinese vendor of one machine says that their machine, which comes with a controller (creation cte 3025), can run ".nc" files only. Can LazyCAM convert Rhino files in ".nc" format? Does it need to for the engraver to work (not getting many clear answers from the vendor) ? If not, then can I simply install Mach 3 instead as the controller software and run with LazyCAM?
Don
Graham Waterworth
2,785
Re: DFX to G Code
Reply #6 on:
December 21, 2007, 05:32:35 AM »
Hi Don,
I think the .NC files will be text based g-code files. The best thing to do is ask them for a sample .NC file and post it here for us to look at.
Graham.
dmai
3
Re: DFX to G Code
Reply #7 on:
December 26, 2007, 04:40:31 AM »
Graham,
here's a sample .nc file.
Don
Graham Waterworth
2,785
Re: DFX to G Code
Reply #8 on:
December 26, 2007, 04:43:17 AM »
All you have to do to use the files is change the extension to .TAP, They will then load into Mach
Graham.
dmai
3
Re: DFX to G Code
Reply #9 on:
December 26, 2007, 04:50:27 AM »
K- that was easy- thanks and happy holidays!
Don
Print
Pages:
1
2
3
Go Up
« previous
next »
