Hello Guest it is November 19, 2026, 05:56:48 PM
Author Topic: DFX to G Code  (Read 43980 times)
toppcatt22
DFX to G Code
« on: June 12, 2007, 01:14:39 PM »
 ???  ??? I have a 3-D wireframe turboCAD drawing as well as the .DXF that I want to convert to a G code. So far no luck but I have yet to purchase the product, is this why I am experiencing troubles? Also, does mach3 do the 3D stimulation?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: DFX to G Code
« Reply #1 on: June 17, 2007, 06:05:49 PM »
You will have to drop the file into a 3d CAM system and generate the code, then mach will run the code.
Graham.
Re: DFX to G Code
« Reply #2 on: July 20, 2007, 02:17:12 AM »
I'm basically needing to do the same thing. I need to convert a dxf file into gcode. Any suggestions of what software? Nick.
  •  2,785 2,785
Re: DFX to G Code
« Reply #3 on: July 20, 2007, 08:55:57 AM »
LazyCAM Pro will do the 2D/2.5D stuff, if your budget stretches into 1000,s then look at AlphaCAM, OneCNC, MasterCAM, BobCAD/CAM, Etc.
Graham.
Re: DFX to G Code
« Reply #4 on: August 06, 2007, 08:12:36 PM »
Hi I have access to master cam any tutorials on how to do this I can use the computer with master cam if I take the files I make with me
Re: DFX to G Code
« Reply #5 on: December 20, 2007, 08:34:43 PM »
I'm looking into getting a cnc engraver, working to turn rhino 3d files into 3d models. The chinese vendor of one machine says that their machine, which comes with a controller (creation cte 3025), can run ".nc" files only. Can LazyCAM convert Rhino files in ".nc" format? Does it need to for the engraver to work (not getting many clear answers from the vendor) ? If not, then can I simply install Mach 3 instead as the controller software and run with LazyCAM?
Don
  •  2,785 2,785
Re: DFX to G Code
« Reply #6 on: December 21, 2007, 05:32:35 AM »
Hi Don,
I think the .NC files will be text based g-code files.  The best thing to do is ask them for a sample .NC file and post it here for us to look at.
Graham.
Re: DFX to G Code
« Reply #7 on: December 26, 2007, 04:40:31 AM »
Graham,
here's a sample .nc file.
Don
  •  2,785 2,785
Re: DFX to G Code
« Reply #8 on: December 26, 2007, 04:43:17 AM »
All you have to do to use the files is change the extension to .TAP,  They will then load into Mach
Graham.
Re: DFX to G Code
« Reply #9 on: December 26, 2007, 04:50:27 AM »
K-  that was easy- thanks and happy holidays!
Don
