Hello Guest it is November 27, 2026, 05:30:20 PM
Author Topic: Screen 4 for lathe  (Read 13251 times)
Offline MarkC
  •  94 94
Screen 4 for lathe
« on: June 10, 2007, 06:56:56 PM »
Does the command"set next line" not work in lathe (V2.0.040)?
I added a button to my screen and when I press it I get the diologue and menu for"run from here"
Thanks in advance
Mark
Re: Screen 4 for lathe
« Reply #1 on: June 11, 2007, 08:53:29 AM »
I don't think it will work :(
We will have to redo that section of code to get that working in Lathe.
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline MarkC
  •  94 94
« Reply #2 on: June 11, 2007, 07:31:31 PM »
OK
Thanks Brian, I think I've found out how to post code so I can use the "Run From Here" command instead
Mark
« Last Edit: June 11, 2007, 07:35:56 PM by MarkC »
Mark
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #3 on: June 12, 2007, 09:24:55 AM »
Hi, Mark
Hears a Turn.Lset based on mill screens with added big screen and Lathe Tab pop-out MPG, It's a work in progress .Lset
Had to Zip it, Hay Brian when you get time could you Add .Lset to file Up-Load Options Hear, Thanks.
Hope this Helps, Chip
« Reply #4 on: June 12, 2007, 02:36:30 PM »
Hi Chip, I have added lset to the list, hope it works.
Offline MarkC
  •  94 94
« Reply #5 on: June 12, 2007, 07:46:17 PM »
Hey Chip Thanks.
I've been wanting to do a screenset based on mill for the lathe. This gives me a head start
Mark
Mark
Offline Chip
  •  2,055 2,055
« Reply #6 on: June 12, 2007, 08:57:35 PM »
Hi, Hood & Mark
Looks like it works
Working on the Lset when time permits, enjoy.
Thanks, Chip
