Mach Discussion => General Mach Discussion => Topic started by: MarkC on June 10, 2007, 07:56:56 PM
Does the command"set next line" not work in lathe (V2.0.040)?
I added a button to my screen and when I press it I get the diologue and menu for"run from here"
Thanks in advance
I don't think it will work :(
We will have to redo that section of code to get that working in Lathe.
Brian
OK
Thanks Brian, I think I've found out how to post code so I can use the "Run From Here" command instead
Mark
Hi, Mark
Hears a Turn.Lset based on mill screens with added big screen and Lathe Tab pop-out MPG, It's a work in progress .Lset
Had to Zip it, Hay Brian when you get time could you Add .Lset to file Up-Load Options Hear, Thanks.
Hope this Helps, Chip
Hi Chip, I have added lset to the list, hope it works.
Hey Chip Thanks.
I've been wanting to do a screenset based on mill for the lathe. This gives me a head start
Mark
Hi, Hood & Mark
Looks like it works
Working on the Lset when time permits, enjoy.
Thanks, Chip
