Hello Guest it is October 23, 2026, 05:22:56 AM
Author Topic: New Screenset for Mach3 Turn is here!  (Read 731668 times)
Re: New Screenset for Mach3 Turn is here!
« Reply #50 on: March 17, 2020, 01:38:01 PM »
Hello, is the ScreenSet still up to date? Is it still available to buy? Which version is current?
Greetings Claus
Offline DaBase
  •  36 36
  • Metalhead
« Reply #51 on: March 22, 2020, 03:48:48 AM »
It is available there is only one version.
We <3 to Code();
Offline DaBase
  •  36 36
  • Metalhead
« Reply #52 on: March 22, 2020, 03:50:14 AM »
Screenset price is 30+1.7fee=31.70 euro, if You want to purchase screen set , send me message.
We <3 to Code();
« Reply #53 on: March 25, 2020, 12:31:32 AM »
« Reply #54 on: March 25, 2020, 01:52:39 AM »
Can you please send me a paypal invoice for the screen set? Imperial, in US currency. Freddyc51@hotmail.com. Thanks
Offline DaBase
  •  36 36
  • Metalhead
« Reply #55 on: March 25, 2020, 03:28:35 AM »
Email is sent.
We <3 to Code();
Offline Rimmel
  •  284 284
« Reply #56 on: March 25, 2020, 06:52:48 AM »
Hi people - I was looking at purchasing this and then saw that the threading was using G94 (mm/min). I use the standard Mach3 *********.062 and as such it uses G95 (mm/rev).
How will this effect my threading Gcode  - (the stuff I already have)
thanks
Steve
« Reply #57 on: March 25, 2020, 06:14:06 PM »
Got it! Very fast response. Thanks
Offline DaBase
  •  36 36
  • Metalhead
« Reply #58 on: March 26, 2020, 02:16:05 AM »
thanks
Steve
Your current G-codes that is working will continue to work. Read first 2 posts and pay attention to 2nd post. All is working and tested.
Modified "Quick Threads" from G76 to G32 cycles with working threading for lathes.
G76 did not worked because of rapid infeed at crazy rates, for example, in metric threads at 1000RPM and pitch 1.5mm machine started operating at F1.5/rev ignoring Mach3 Motor Tuning settings and tried to do rapid feed on very small distances at 1500mm/min momentary which causes missing steps for steppers and PID error for Servo systems.
Everything is tested and works with included Threading wizard
We <3 to Code();
« Reply #59 on: March 26, 2020, 05:01:46 AM »
Hi
Installed on my stand alone test computer and looking good.
Can I use the same download on my test computer to install it on the actual machine one via a USB stick?
Grayhil
