Hello Guest it is October 23, 2026, 05:22:27 AM
Author Topic: New Screenset for Mach3 Turn is here!  (Read 731666 times)
Re: New Screenset for Mach3 Turn is here!
« Reply #70 on: January 20, 2021, 10:42:54 PM »
I want to buy your product.
How do we proceed?
AndrewUM
Offline DaBase
  •  36 36
  • Metalhead
« Reply #71 on: January 21, 2021, 06:31:51 AM »
Write PM.
We <3 to Code();
« Reply #72 on: March 05, 2021, 07:01:42 AM »
hi
i have sent a pm requesting to purchase your screenset
thanks
« Reply #73 on: June 20, 2021, 01:35:34 PM »
Ease-eTurn screenset --- Metric version has been installed ....
but I can not get permission to enter numbers in the 2 red circles on the image ...
and before that I can not be allowed to proceed ...
I enter a number and press enter and immediately after that the field is blank again ???? regardless of whether there is an - or + before the number
someone here in the forum who has an idea what is wrong ????
Tried to reinstall without success. :-
« Reply #74 on: July 02, 2021, 02:23:19 PM »
Hello, I would like to buy the easy turn screen, where can I get it, thank you.
mp send thanks
« Last Edit: July 02, 2021, 02:25:21 PM by axel30 »
« Reply #75 on: July 22, 2021, 09:17:40 PM »
Hi
Is this still available.
Deon
If A is a success in life, then A equals X plus Y plus Z.
                               Work is X: Y is play and Z is keeping
                                                             your mouth shut.
« Reply #76 on: January 29, 2022, 07:39:36 PM »
We are glad to announce the new Ease-eTurn for Lathe!
Price for the Screenset is 25 Eur via PayPal, please write me PM about buying it.
Sent you a PM, hoping it's still available for purchase.
Thanks.
« Reply #77 on: January 30, 2022, 02:57:38 PM »
I just sent an email from DaBase,s members details asking for latest price and payment method.
Graham
« Reply #78 on: January 30, 2022, 03:36:12 PM »
Graham
Thank you Graham!
« Reply #79 on: April 08, 2022, 04:28:05 AM »
hi,
would love to buy this screenset. can you email me your Paypal? and how I can download all files after paying?
thank you
We are glad to announce the new Ease-eTurn for Lathe Screenset!
This thing turns your Mach3 Turn into completely user friendly product!
Features:
16:9 ratio adjusted Screenset! Enough with the old-fashioned 1024x768!
Large toolpath window
Files included for CSMIO-IP/S by CS-Lab
Completely rebuilt wizards in Conversational tab, including Quick Threads by Poppabear in new look!
Settable safe Toolchange Position with one click button and safety, saving time on long and unneeded travels, also usable with M code
Lubrication alarm for users with Auto lubrication system
Machine operated (air or hydraulic) collet chuck or jaw chuck opening/closing by one click button, also usable with M code, with displaying current status LED
Distance To Go for visual reference to avoid any crash
Current Work Offset (G54, G55, G56 etc.) appearance on display
Feed override slider
Spindle override slider
Spindle load monitoring in two ways:
* By reading from VFD analog output (0-10V)
* By comparing True and Set RPM
Spindle Stall detection with LED
Optional Hydraulics/Air compressor On/Off switch
Feed per Rev setting by one click button
Constant Surface Speed (CSS) setting by one click button
Easy to use separate Offsets window for setting Tool and Work offsets
Separate window for all coordinate systems (Machine, Axis, Work)
M01 Break (Optional Stop) button with LED
Included Macro for rotational or linear Automatic Tool Change with logics to go shortest distance, easy to configure for 4-bit encoder or using switches
User friendly safety logics preventing against crash
* Collet Open/Close preventing Spindle Start, Cycle Start
* Protection against wrong tool (for example, Tool 0 instead of 1) by warning user with pop-up window
* Preventing Cycle Start before homing all axis after Reset
* Waiting for Spindle while it spins up to commanded RPM, then allows program to continue
Conversational part features:
Easy-to-use wizards
Usable in both - radius and diameter mode
Option to append multiple wizards in one usable G-code file
Brain included:
Brain for Collet Signal On/Off (for one pin)
Brain for controling Hydraulics (settable Output pin) button on screenset
Brain for external Pause and Stop buttons
Brain for Spindle Stall Detection (must use RPM counter on Spindle)
Brain for Spindle Load meter, if no Analog Input from VFD (comparing True RPM and Commanded RPM)
Brain for Chuck opening/closing safety, so when Spindle is turning, it is impossible to open it
Brain for Lubrication alarm (no oil)
Currently Screenset is made for Metric users, in few days Imperial version will be ready.
Install instructions are on YouTube: https://www.youtube.com/watch?v=emUI7DDnI6k
