Hello Guest it is November 11, 2026, 11:14:26 PM
Author Topic: 2 questions  (Read 11014 times)
2 questions
« on: November 11, 2016, 09:16:39 AM »
first when i load a file the tool path it is displayed but when i start the cycle all that is shown is the cursor moving.  and second when i go to reset the motosr still make noise have depower the board to make them go silent     thanx
toolpath help
« Reply #1 on: November 17, 2016, 06:42:04 PM »
Well ive gotten no where on the general board so i'll try here ???  first when i load a file the tool path it is displayed but when i start the cycle all that is shown is the cursor moving.  and second when i go to reset the motosr still make noise have depower the board to make them go silent     thanx
  •  9,377 9,377
Re: toolpath help
« Reply #2 on: November 18, 2016, 02:16:21 AM »
Hi Jake,
I am sorry you did not get a prompt reply to your original question.
Can you attach your .xml file. It is located in your Mach3 folder and is called <your profile>.xml
Copy it and rename the copy to jake100.xml then use the Reply / Additional Options to attach the file.
What make and model controller are you using to drive your stepper motors ?
Re: 2 questions
« Reply #3 on: November 20, 2016, 12:48:58 PM »
Forgot to include I'm useing a chinese control and motors I think form Long motors
  •  9,377 9,377
Re: 2 questions
« Reply #4 on: November 21, 2016, 01:16:19 AM »
If you are using Long's Motor parts then you should be able to identify the model of your controller from the pictures / description on their site http://www.longs-motor.com/
Please attach your .xml file
