Hello
Guest
it is
October 20, 2026, 10:02:58 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
LOVING the PMC!! Thanks Steve!!!
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: LOVING the PMC!! Thanks Steve!!! (Read 50573 times)
thespindoctor
307
Re: LOVING the PMC!! Thanks Steve!!!
Reply #30 on:
November 20, 2016, 05:39:14 PM »
Where is the PMC to be found and any docs on it?
Keith
TOTALLYRC
872
Reply #31 on:
November 20, 2016, 06:05:59 PM »
You need Mach4 version 4 ******************.3112. Under configure select PMC. Docs are in the mach4 doc folder, PMC.
Mike
thespindoctor
307
Reply #32 on:
November 20, 2016, 06:32:55 PM »
Thanks Mike!!
TOTALLYRC
872
Reply #33 on:
November 20, 2016, 06:51:03 PM »
No problem.
I am just spreading the PMC love!!!!
thespindoctor
307
Reply #34 on:
November 20, 2016, 07:21:41 PM »
I want to fall in love too! But when to use this is in Mach4.
Is it just to deal with inputs and outputs monitoring activities or could it be used to write a probe routine for instance?
Keith
TOTALLYRC
872
Reply #35 on:
November 20, 2016, 07:48:46 PM »
While the PMC is very powerful I am not sure if you can do that with it.
Mike
arturod
172
Reply #36 on:
June 09, 2017, 07:58:26 AM »
It looks like PMC is still not doing calculations with decimals:
Arturo Duncan
http://cnc4pc.com
smurph
1,575
"That there... that's an RV."
Reply #37 on:
June 09, 2017, 11:36:00 AM »
Arturo,
I need an example. Because what I just tested works. Can you post the PMC file?
Steve
arturod
172
Reply #38 on:
June 09, 2017, 12:01:37 PM »
Here it is.
I had to add the .txt so it would allow to upload it.
Arturo Duncan
http://cnc4pc.com
smurph
1,575
Reply #39 on:
June 09, 2017, 05:23:59 PM »
Ok Arturo, I think I have it. Thanks for the example because the math portion was working correctly. The error was with reading and writing registers. The fix will be in the next build.
Steve
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
