Hello Guest it is October 20, 2026, 10:03:00 AM
Author Topic: LOVING the PMC!! Thanks Steve!!!  (Read 50573 times)
Re: LOVING the PMC!! Thanks Steve!!!
« Reply #30 on: November 20, 2016, 05:39:14 PM »
Where is the PMC to be found and any docs on it?
Keith
« Reply #31 on: November 20, 2016, 06:05:59 PM »
You need  Mach4 version 4 ******************.3112. Under configure select PMC. Docs are in the mach4 doc folder, PMC.
Mike
« Reply #32 on: November 20, 2016, 06:32:55 PM »
Thanks Mike!!
« Reply #33 on: November 20, 2016, 06:51:03 PM »
No problem.
I am just spreading the PMC love!!!!
« Reply #34 on: November 20, 2016, 07:21:41 PM »
I want to fall in love too! But when to use this is in Mach4.
Is it just to deal with inputs and outputs monitoring activities or could it be used to write a probe routine for instance?
Keith
« Reply #35 on: November 20, 2016, 07:48:46 PM »
While the PMC is very powerful I am not sure if you can do that with it.
Mike
« Reply #36 on: June 09, 2017, 07:58:26 AM »
It looks like PMC is still not doing calculations with decimals:
Arturo Duncan
http://cnc4pc.com
Offline smurph
  •  1,575 1,575
« Reply #37 on: June 09, 2017, 11:36:00 AM »
Arturo,
I need an example.  Because what I just tested works.  Can you post the PMC file?
Steve
« Reply #38 on: June 09, 2017, 12:01:37 PM »
Here it is.
I had to add the .txt so it would allow to upload it.
Arturo Duncan
http://cnc4pc.com
Offline smurph
  •  1,575 1,575
« Reply #39 on: June 09, 2017, 05:23:59 PM »
Ok Arturo, I think I have it.  Thanks for the example because the math portion was working correctly.  The error was with reading and writing registers.  The fix will be in the next build.
Steve
