Hello Guest it is November 13, 2026, 01:29:40 PM
Author Topic: Auto Zero Touch off issues  (Read 22565 times)
Offline Toad
  •  58 58
« on: February 19, 2016, 02:05:14 PM »
Hi all.
I have started having issues with my auto zero.
When I click on auto tool zero, the tool moves down as it should, but when it touches the touch off plate it does not always respond. The Digitize LED comes on every time in the diagnostics screen, but the spindle keeps going down. Most of the time it works correctly, other times it is ignored.
I tried reloading the edit script again, but makes no difference.
Any thoughts on what may be going on.
Toad
Re: Auto Zero Touch off issues
« Reply #1 on: February 20, 2016, 08:28:44 AM »
Do you have soft limits enabled when doing this?
If so, disable it and try again.
Offline Toad
  •  58 58
« Reply #2 on: February 20, 2016, 10:12:24 AM »
soft limits are not enabled.
Could it be in the BOB? When plate is grounded, LED on BOB lights up as well.
« Reply #3 on: February 20, 2016, 10:23:16 AM »
Post your script here.
Offline Toad
  •  58 58
« Reply #4 on: February 22, 2016, 12:02:59 PM »
Here it is, I have tried others, and all do the same. Usually when it messes up, I can reset mach, and it will work correctly
« Reply #5 on: February 22, 2016, 01:32:49 PM »
Did it work correctly in the past?
What version of Mach3?
Offline Toad
  •  58 58
« Reply #6 on: February 22, 2016, 01:44:05 PM »
Version 3.043.066
It has been working fine up to about a week ago.
« Reply #7 on: February 22, 2016, 02:02:42 PM »
Try 3.043.062.
Several people using the auto zero in my screenset have had issues with that version when using a smoothstepper.
Offline Toad
  •  58 58
« Reply #8 on: February 23, 2016, 11:03:22 AM »
where can I get that version. all I can find to download is the newer version I have already
Toad
Offline Toad
  •  58 58
« Reply #9 on: February 23, 2016, 11:32:07 AM »
I found it & Downloaded, Now when I touch to ground, the BOB LED lites up, so does the Diagnostics screen LED  , I checked connections and they appear to be tight and secure. but it does not work.
