Hello Guest it is October 24, 2026, 12:08:01 AM
Author Topic: Mach4 with ESS and PMDX126/107 speed control issues.  (Read 77130 times)
Offline dude1
  •  1,253 1,253
Re: Mach4 with ESS and PMDX126/107 speed control issues.
« Reply #50 on: February 24, 2016, 05:13:39 PM »
one other thing you have motor 0 set as 0 good.
then you have motor 1 set in motors tab then in Axis mapping you have motor 2 set as motor 1.
you should have motor 2 set as motor 2 in motors and Axis mapping
Offline joe45
  •  25 25
« Reply #51 on: February 25, 2016, 12:14:11 PM »
Ok, so I have tried your suggestions and it would appear to have made it worse. I now cannot move the motors at all, and the pins do not change when a gcode is entered for the spindle, only when the CW button is clicked. I have a log attached of the spindle code running. I have attached the new .INI and profile.
« Reply #52 on: February 25, 2016, 02:29:17 PM »
OK - this is not at all a PMDX issue and I'm done playing "guess what non-obvious configuration is needed".  Time to get Warp9 to support their own product.  Try posting on their forums and see if anyone can explain how to get PWM out of the ESS.  Go here:
     http://warp9td.com/index.php/kunena/index
You have to create an account to even browse the forums :-(
If you find out it would be helpful to people here for you to post the settings necessary for this.
Bob
Offline joe45
  •  25 25
« Reply #53 on: February 25, 2016, 03:01:53 PM »
Thanks for all your help Bob, I have posted on their forums and will report back if there is any news. I am of course still open for help from this page if there are any other ideas.
Thanks again
Joe
Offline dude1
  •  1,253 1,253
« Reply #54 on: February 25, 2016, 04:55:54 PM »
Joe what ever you do is going to change a a few weeks
Offline joe45
  •  25 25
« Reply #55 on: February 25, 2016, 05:45:51 PM »
How so?
Offline royce
  •  40 40
« Reply #56 on: February 25, 2016, 06:26:15 PM »
How so?
Warp9 is coming out with a new plug-in release that will be be totally different integration geared towards Mach4. Could be weeks, months, who knows but ESS users have been waiting a very long time.
Bridgeport Series 1 Rigid Ram Retrofitted w/PMDX126 BOB, PMDX107, Hitachi WJ200 VFD,ESS, Leadshine DM2282 Drivers running Mach4 comfortably.
Offline dude1
  •  1,253 1,253
« Reply #57 on: February 25, 2016, 06:36:52 PM »
it's not months, weeks
Offline joe45
  •  25 25
« Reply #58 on: February 26, 2016, 12:13:51 AM »
Well that will be extremely helpful. Hopefully it isn't too far away...
Offline dude1
  •  1,253 1,253
« Reply #59 on: February 26, 2016, 01:03:13 AM »
let you know next week did you double check what I asked over on ESS forum
