Hello Guest it is November 13, 2026, 02:01:59 PM
Author Topic: Motor tuning setup - Need help  (Read 11315 times)
« on: February 13, 2016, 01:38:39 PM »
Hi All
I have a DM542A driver and nema 23 425oz.
I need to put the right parameters in mach3, motor tuning.
I am not sure which settings that are the best. For this setup
Can anyone help on the track, thanks.
Re: Motor tuning setup - Need help
« Reply #1 on: February 13, 2016, 02:05:49 PM »
http://www.machsupport.com/help-learning/product-manuals/
Its all in there.
Please post again if you have specific issues that you can't seem to resolve.
Russ  :)
« Reply #2 on: February 17, 2016, 03:54:16 PM »
I have collected some information about the equipment.
Can someone help to put all this together.
Nema 23 425oz
Step angel 1.8"
Current 3A
Shaft 8mm
DM542A
SW 1, 2, 3 on, on, off
4 off
SW 5, 6, 7, 8
Can be
400, 800, 1600, 3200 and so on....
I don't know which one to choose
Trapez 12mm
Pitch 3mm from top to top
But how do I calculate all this information correct.
So it fit in mach3?
Am I still missing something
« Reply #3 on: February 17, 2016, 05:00:27 PM »
Step angle 1.8 = 200 pulses per revolution
Set the switches for 2000 micro stepping
3mm pitch screw
2000 / 3 = 666.66666666666666 steps per unit (mm)
« Reply #4 on: February 17, 2016, 05:05:16 PM »
Thanks for your reply...
I was getting 533 or 1066, so something may I have done wrong.
Now I will take a closer look at your post.
