Hello Guest it is September 13, 2026, 06:32:22 PM
Author Topic: ******Guess and win a G100 Grex******  (Read 954016 times)
Re: ******Guess and win a G100 Grex******
« Reply #30 on: May 15, 2007, 07:46:42 AM »
Hi all,
Just my two cents.  2,501,786 no, maybe 2,701,678no maybe 2,500,076
« Last Edit: May 24, 2007, 03:01:25 PM by bclark »
Brian
Slowboy
« Reply #31 on: May 15, 2007, 08:41:26 AM »
My guess.. 2,999,999
« Reply #32 on: May 15, 2007, 08:57:44 AM »
I'm thinkin'............ 2,500,000 +/- 1
Tim
« Reply #33 on: May 15, 2007, 09:45:07 AM »
Hmmmm.
It's obviously larger than an buttload....
...but seems smaller than an a$$load......
My guess is that it's a $hitload
« Reply #34 on: May 15, 2007, 09:51:48 AM »
Think my guess would have to be 2,567,890
« Reply #35 on: May 15, 2007, 10:44:29 AM »
Assuming a 50% duty cycle and a full 8 hour day, 2,736,000!
« Reply #36 on: May 15, 2007, 10:55:59 AM »
2218782  Can't win if you don't play (from a cheesy Florida lottery billboard)
« Reply #37 on: May 15, 2007, 11:04:33 AM »
OKl I'll play - having subjected the clues given so far to a bit of dimensional analysis, the spread sheet says that a crucial piece of info is missing... Please provide a hint re the diameter of the cutter used and I will have the magic formulas provide THE answer as my entry.
« Reply #38 on: May 15, 2007, 11:11:32 AM »
OK -  I'll play.
I've carefully considered the clues given so far; subjected them to a bit of dimensional analysis and constructed a modelling spread sheet... alas, two crucial piece of info are still needed....
1) what diameter cutter was used?
2) I also need to know what type of shoe soles you were wearing and how many times you left the area during the job (to subtract out the chips removed via this process).
With these missing pieces I can complete the variables of the formula (and use some rational estimations of finish vs roughing feed/speed ratios), and I will have the magic model provide my answer for entry.
Offline klmark
  •  107 107
« Reply #39 on: May 15, 2007, 11:28:14 AM »
Hi Guys
You just as well quick i think I got it 2,299,371 But again I could be wrong that would be the first time   ha ha ah aha
« Last Edit: May 18, 2007, 04:30:11 PM by klmark »
