Hello
Guest
it is
November 13, 2026, 05:53:52 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
PoKeys57CNC and Mach3 Softlimits
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: PoKeys57CNC and Mach3 Softlimits (Read 13927 times)
Dan13
1,208
on:
February 02, 2016, 02:15:09 PM »
Should softlimits work with this setup? I am not able to turn softlimits on in Mach3. Getting the message that I am beyond limits, although I am within the defined envelope.
Logged
NeoTO
504
Re: PoKeys57CNC and Mach3 Softlimits
Reply #1 on:
March 07, 2016, 10:47:33 PM »
If you are getting this message, the message is coming from Mach3. Check your settings first (and machine coordinates!).
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Dan13
1,208
Reply #2 on:
March 07, 2016, 11:49:14 PM »
Thanks. Restarting Mach helped solve this. However, still have a problem of the axes not stopping exactly at the defined soft limit, but rather overshooting by an amount depending on the feed rate.
Logged
NeoTO
504
Reply #3 on:
March 08, 2016, 02:04:58 PM »
This is how soft limits are implemented in PoKeys device. In Mach4, soft limits are taken over by Mach4 and the axes stop spot on.
Logged
www.poscope.com
Print
Pages:
1
Go Up
« previous
next »
