Hello Guest it is November 13, 2026, 03:01:36 PM
Author Topic: Strange problem with circles  (Read 8583 times)
« on: January 26, 2016, 05:50:17 PM »
I have been using mach3 for a while now originally on a home designed and built wood router, recently I upgraded and Brought an ooznest OX which I am really happy with. I do have a strange problem, I use Artcam Express for most of my path generation, if I produce a simple square inlay the parts fit perfect, if however I use curves the don't can anyone suggest where I should start looking, simulation shows the Artcam paths to be accurate, I can only assume it is a setting in Mach but not sure where to look.
Any ideas greatly received
Tony
Offline rcaffin
  •  1,073 1,073
Re: Strange problem with circles
« Reply #1 on: January 27, 2016, 02:41:25 AM »
Read up about the difference between Incremental IJ mode and Absolute mode.
makes the circles look wrong. Very common problem.
Roger
