Mach Discussion => General Mach Discussion => Topic started by: TonyWood on January 26, 2016, 06:50:17 PM
I have been using mach3 for a while now originally on a home designed and built wood router, recently I upgraded and Brought an ooznest OX which I am really happy with. I do have a strange problem, I use Artcam Express for most of my path generation, if I produce a simple square inlay the parts fit perfect, if however I use curves the don't can anyone suggest where I should start looking, simulation shows the Artcam paths to be accurate, I can only assume it is a setting in Mach but not sure where to look.
Any ideas greatly received
Tony
Read up about the difference between Incremental IJ mode and Absolute mode.
makes the circles look wrong. Very common problem.
Roger
