Hello Guest it is November 02, 2026, 02:08:48 PM
Author Topic: Problems starting up with lazyturn  (Read 181312 times)
Re: Problems starting up with lazyturn
« Reply #30 on: January 31, 2016, 05:37:33 AM »
yes I have installed that one
« Reply #31 on: January 31, 2016, 05:49:59 AM »
Here is what I would suggest:
You can run LT outside of MACH / independently:
So create a directory / folder, say call it, Lazyturn.
Now install LC, the update to LC, and the LT version in that folder.
This should be done per what is written in the manual.
Run LT from that folder.
I don't know what else to say,
« Reply #32 on: January 31, 2016, 05:56:21 AM »
Better yet,
Install on a thumb drive, and run it in XP.
I will do exactly what is in the manual putting it on a thumb drive and run from XP, but probably won't be today.
Got to go,
« Reply #33 on: January 31, 2016, 06:32:43 AM »
I just checked and I am running windows 10 and LT 1.1. I am able to do a rough and a fine pass without any problems.
The only error message that I get is if the first tool doesn't leave any material for the fine pass.
Mike
« Reply #34 on: February 01, 2016, 12:51:44 PM »
 :)Rich nd Mike,
Thank for your help.
Finally it works the only thing Im yet facing is that in the rel world the settings doesnot correspond.
1mm equls in mach3 now 0,05 mm so that the machine blocks t the end.
Il have to find this out because manul control and wizrds are working well.
Kind regrds,
ndre
« Reply #35 on: February 01, 2016, 06:53:01 PM »
Happy you got it working. :)
Not sure what you saying in your reply.
For LT, if in metric, draw in mm, use LT in mm, Mach should be configured for mm.
