Hello Guest it is November 03, 2026, 08:48:57 AM
Author Topic: Soft Limits  (Read 11533 times)
Soft Limits
« on: January 03, 2016, 09:25:33 AM »
I searched and read a lot of posts on soft limits and nothing really applied...maybe I am overlooking something simple...setting seem right and the machine is homed...
Any suggestions?
Re: Soft Limits
« Reply #1 on: January 03, 2016, 09:53:35 AM »
Not sure what the question is, but do you have Somtlimits turned on?
Re: Soft Limits
« Reply #2 on: January 03, 2016, 09:58:04 AM »
Hmmmm..cant find anywhere to "turn them on"? I have them set up in home/limits, looked in general config, cant find any toggle to enable them. The original question was why is it running fine when I exceed soft limits?
Re: Soft Limits
« Reply #3 on: January 03, 2016, 10:07:18 AM »
You need to add a button to turn them on and off.
You also want an LED to show you when they are on or off.
They are probably not turned on.
Re: Soft Limits
« Reply #4 on: January 03, 2016, 10:07:54 AM »
That looks like a modified Aqua screen? The default Aqua has a Softlimits button.
Re: Soft Limits
« Reply #5 on: January 03, 2016, 10:08:38 AM »
Thanks! Once again a simple solution I missed! Probably in the manual!
Re: Soft Limits
« Reply #6 on: January 03, 2016, 10:09:19 AM »
Duh! I should have looked thru the original!
