Hello Guest it is October 16, 2026, 12:24:49 AM
Author Topic: How to change an image into Mach 3 language  (Read 14422 times)
Offline AJA
  •  26 26
« on: December 14, 2015, 08:45:54 AM »
I have been asked to make a brand for a logo.  How do I change an image into a language that Mach 3 will accept?
This will be done on a vertical mill.
Any help is greatly appreciated.
AJ
Re: How to change an image into Mach 3 language
« Reply #1 on: December 14, 2015, 08:46:42 AM »
Load it into a CAD program and trace it. Then bring the tracing into a CAM program.
Offline AJA
  •  26 26
« Reply #2 on: December 14, 2015, 02:39:24 PM »
 My cad will only output a .dwg file.  How can I convert that g code?  Lazy cam does not work.
« Reply #3 on: December 14, 2015, 03:03:28 PM »
Most other CAM programs can read a .dwg file.
Are you sure you can't save as a .dxf? Almost every CAD program can.
Offline AJA
  •  26 26
« Reply #4 on: December 14, 2015, 03:37:51 PM »
Lazy cam will not read any of the dxf file that I save the cad fill in?
« Reply #5 on: December 14, 2015, 05:26:52 PM »
Save as the oldest version of .dxf file that you can, preferable v12 or older.
Offline AJA
  •  26 26
« Reply #6 on: December 14, 2015, 05:37:39 PM »
I've tried R12 asc II, R14 asc II, R2000-2004, R12,13, and 14 binary among others.
Any other ideas would be appreciated.
(No subject)
« Reply #7 on: December 16, 2015, 03:46:20 PM »
As far as I know a dxf file is just a text file so open it in notepad and see if you can read it.
I hope this helps Brian
www.ebolt.co.uk
