Hello
Guest
it is
October 15, 2026, 11:26:56 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
How to change an image into Mach 3 language
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: How to change an image into Mach 3 language (Read 14420 times)
AJA
26
on:
December 14, 2015, 08:45:54 AM »
I have been asked to make a brand for a logo. How do I change an image into a language that Mach 3 will accept?
This will be done on a vertical mill.
Any help is greatly appreciated.
AJ
Logged
ger21
6,295
Re: How to change an image into Mach 3 language
Reply #1 on:
December 14, 2015, 08:46:42 AM »
Load it into a CAD program and trace it. Then bring the tracing into a CAM program.
Logged
AJA
26
Reply #2 on:
December 14, 2015, 02:39:24 PM »
My cad will only output a .dwg file. How can I convert that g code? Lazy cam does not work.
Logged
ger21
6,295
Reply #3 on:
December 14, 2015, 03:03:28 PM »
Most other CAM programs can read a .dwg file.
Are you sure you can't save as a .dxf? Almost every CAD program can.
Logged
AJA
26
Reply #4 on:
December 14, 2015, 03:37:51 PM »
Lazy cam will not read any of the dxf file that I save the cad fill in?
Logged
ger21
6,295
Reply #5 on:
December 14, 2015, 05:26:52 PM »
Save as the oldest version of .dxf file that you can, preferable v12 or older.
Logged
AJA
26
Reply #6 on:
December 14, 2015, 05:37:39 PM »
I've tried R12 asc II, R14 asc II, R2000-2004, R12,13, and 14 binary among others.
Any other ideas would be appreciated.
Logged
bwprice100
79
(No subject)
Reply #7 on:
December 16, 2015, 03:46:20 PM »
As far as I know a dxf file is just a text file so open it in notepad and see if you can read it.
I hope this helps Brian
www.ebolt.co.uk
Logged
Print
Pages:
1
Go Up
« previous
next »
