Hello Guest it is October 24, 2026, 12:45:22 PM
Author Topic: E-stop error??  (Read 39240 times)
E-stop error??
« on: May 06, 2007, 08:32:10 PM »
Hello all,
I am getting an e-stop error as if a switch was activated. There is no pattern to this, it even happens when the machine is just sitting there. I have checked each switch in the diagnostic screen, and raised the debounce from 2000 to 3000.
Any thoughts???
Ken
Re: E-stop error??
« Reply #1 on: May 06, 2007, 08:35:46 PM »
Sounds like it could be a noise problem.
Re: E-stop error??
« Reply #2 on: June 30, 2007, 11:48:41 AM »
i have the same problem did you get it fixed could you help me out
Re: E-stop error??
« Reply #3 on: July 20, 2007, 05:58:57 PM »
Hello,
The problem is, what kind of noise is coursing this problem.
If it is a spike or puls from a quit high frequency what is coursing is problem, you can try to solder a 5nF capacitor paralel on the switch or even better as near as possible on the computer or breakoutboard.
But it even couldt be a bad connection.
Wotje
