Hello Guest it is November 18, 2026, 05:06:54 AM
Author Topic: Mach3  (Read 8272 times)
Mach3
« on: September 27, 2015, 06:03:36 AM »
Does Mach3 have the ability to rotate or mirror cutter path?
Paul
Re: Mach3
« Reply #1 on: September 27, 2015, 02:03:25 PM »
Paul,
Have a read of the Mach manual, lost s of good info in it.
You can rotate an axis with G68 and mirror using a (-) in the scale input, if  I recall correctly , see also G51 command.
Re: Mach3
« Reply #2 on: September 28, 2015, 06:57:35 AM »
Paul,
Honestly I have not read the manual beyond my intital startup, but I will do it now.  Thank you for the quick response.
Paul
