Hello Guest it is October 21, 2026, 10:39:29 AM
Author Topic: Mach3 license problem  (Read 16676 times)
« on: September 20, 2015, 04:37:57 AM »
Hello everybody,
I have bought Mach3 license few years ago and is installed in two PCs. Both have worked well.
Now both PCs reports that "Evaluation limit reached". Is there expiration date? Should I buy an new license?
What should I do?
Thanks in advance
BR
Sauli
less is more
Re: Mach3 license problem
« Reply #1 on: September 20, 2015, 06:26:48 AM »
Contact license@machsupport.com
I've never seen this before.
« Reply #2 on: September 20, 2015, 12:29:56 PM »
Thanks Gerry
BR
Sauli
less is more
« Reply #3 on: September 20, 2015, 01:30:19 PM »
I think the problem may be in the screenset (;-)
« Reply #4 on: September 22, 2015, 11:38:07 AM »
license@machsupport.com is for automatic license delivery only.
Same results with standard 1024.set-file
BR
Sauli
less is more
  •  9,374 9,374
« Reply #5 on: September 22, 2015, 11:47:04 AM »
This is a problem I have not seen before and I was surprised to hear that it is not related to the screen .set, as Terry has mentioned.
Please use the contact form to make an inquiry regarding your Mach3 license.  http://www.machsupport.com/contact-us/
« Reply #6 on: September 22, 2015, 07:51:22 PM »
Who did you buy the license from?
« Reply #7 on: September 22, 2015, 08:07:02 PM »
That screenset is normally linked to the Ivan license many times.
« Reply #8 on: September 24, 2015, 10:53:03 AM »
I've bought it from Machsupport Scott Nichols, Feb 10th 2008.
less is more
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #9 on: September 24, 2015, 11:59:51 AM »
who did you buy the sheetcam license from?
