Hello Guest it is October 22, 2026, 06:20:52 PM
Author Topic: 3D Aspire to Mach3.....  (Read 41392 times)
Re: 3D Aspire to Mach3.....
« Reply #20 on: September 08, 2015, 10:50:23 AM »
This One?
« Reply #21 on: September 08, 2015, 10:53:19 AM »
Yep the same one. Getting Aspire error code 126663 which I think is a compatibility problem. What version of Aspire are you using? Is it 32 or 64 bit?
« Reply #22 on: September 08, 2015, 10:54:58 AM »
Aspire 4.015 Where can I see if it is 32 or 64 bit?
Should it be 32?
« Reply #23 on: September 08, 2015, 11:00:18 AM »
4.015 is 32 bit Aspire. The newer Aspire 8.0 is 64 bit but will convert older 32 bit CRV files. I can't open your file in either 4.0 or 8.0 so something is wrong.
« Reply #24 on: September 08, 2015, 11:02:41 AM »
What should I do now?
« Reply #25 on: September 08, 2015, 11:11:33 AM »
The upgrade from Aspire 4.0 to 8.0 is $400. V4.015 works fine unless you want the newer features of V8.0. Try selecting all vectors and exporting as a EPS file. Then post the file.
« Reply #26 on: September 08, 2015, 11:14:07 AM »
Just sent you a PM...
« Reply #27 on: September 08, 2015, 05:59:38 PM »
I can open the file ok and I can't see anything obviously wrong.
There are no calculated toolpaths in the file though.
Which post processor are you using to calculate the toolpaths?
How do you set your Z height?
