Hello Guest it is November 22, 2026, 10:45:20 AM
Author Topic: 3D Aspire to Mach3.....  (Read 42398 times)
Re: 3D Aspire to Mach3.....
« Reply #10 on: September 08, 2015, 10:20:11 AM »
As far as Mach 3 settings... it depends on your machine, steppers, steps per mm, etc. There are no generic. However, you said this is happening with older cnc projects too so it maybe incorrect Mach 3 settings.
« Reply #11 on: September 08, 2015, 10:21:30 AM »
Sorry won't download from a www. site.
« Reply #12 on: September 08, 2015, 10:22:04 AM »
How do I get it here? It says it is to big file
« Reply #13 on: September 08, 2015, 10:25:02 AM »
Save it as a zip file.
« Reply #14 on: September 08, 2015, 10:27:08 AM »
Okay here it is
« Reply #15 on: September 08, 2015, 10:29:34 AM »
The gcode at line 100 has a G21 which is MM.
« Reply #16 on: September 08, 2015, 10:30:35 AM »
What could be wrong??
« Reply #17 on: September 08, 2015, 10:34:31 AM »
I have a CNC3040 and when I start Mach3 so It will automaticlly start to drill a 4mm hole. It should make a 1mm hole...
« Reply #18 on: September 08, 2015, 10:43:09 AM »
Now I just made a box 50 x 50mm and made a pocket toolpath. 2mm deep and it cuts 0.5mm.
That one works okay. But when I make something bigger it dosen't work...
« Reply #19 on: September 08, 2015, 10:44:46 AM »
Can't open the .CRV3d file... tried Aspire 4 & 8. Getting error message.
