Hello Guest it is September 24, 2026, 05:02:23 PM
Author Topic: Ref All Home - problem  (Read 22424 times)
Offline amnon
  •  40 40
« on: September 01, 2015, 12:36:28 PM »
Hej,
I have marked Auto Limit OverRide but when I press Ref All Home it doesn't work.
Best Respect
Amnon
Re: Ref All Home - problem
« Reply #1 on: September 01, 2015, 02:02:30 PM »
Hi Amnon,
 I'm not sure what you are implying, but using the Override you manually jog the axis' well clear of any of the homing/limit switches (being careful to jog in the proper direction as it will allow you to crash if you jog into the switch) then do a Ref All.
Hope this may help,
Russ
Offline amnon
  •  40 40
« Reply #2 on: September 02, 2015, 10:18:45 AM »
Hi Russ,
Thank's, I wasn't clear enough, my limits and homing are connected in series and using only 1 pin on USB port. When I do a home move, first the axis Z moves up, hits the home switch then stops and does not backoff. I can see switches still active on the Diagnostic page. Auto limit override is on,  I did try the debounce at 2000 ... no Change.
I have breakout board:
http://www.ebay.co.uk/itm/5-Axis-USB-Controller-Card-400KHz-CNC-MACH3-Mach4-Breakout-Interface-Board-New-/261479889613?hash=item3ce16a7acd
Best Regards
Amnon
« Reply #3 on: September 02, 2015, 10:21:17 AM »
Debounce in Mach will have no influence as you have an external controller. Look in the plugin and see if there are any filtering/debounce options.
Offline amnon
  •  40 40
« Reply #4 on: September 02, 2015, 12:13:11 PM »
I can't see anythink like filtering/debounce options in plugin Config.
http://ifotos.pl/z/spxnaqr
Best Regards
Amnon
« Reply #5 on: September 02, 2015, 04:20:37 PM »
You seem to be using an older version of Mach, maybe your plugin is incompatible with older versions, that is often the case for external controllers.
Ver 3.043.062  is probably the best one to get, the latest (066) has multiple issues and I would not recommend.
You can find previous Mach versions here ftp://machsupport.com/Mach3/
If that does not help attach your xml and I will see if I can find an issue in it.
Offline amnon
  •  40 40
« Reply #6 on: September 03, 2015, 11:43:49 AM »
Unfortunately no change. Whats more, I separated limit switches from Home switches, when I Ref All Home only Z axis homing without zeroing axis. Strange.
Best Regards
Amnon
« Reply #7 on: September 03, 2015, 01:15:57 PM »
Afraid you are using a pirate licence, that may or may not be contributing to the problem.
Offline amnon
  •  40 40
« Reply #8 on: September 03, 2015, 01:22:04 PM »
I bought this Mach with breakout board in UK.
Best Regards
Amnon
« Reply #9 on: September 03, 2015, 03:18:04 PM »
Seems you were also supplied with a pirate licence for Mach.
