Hello Guest it is October 20, 2026, 09:20:53 PM
Author Topic: Ref All Home - problem  (Read 22621 times)
Offline amnon
  •  40 40
Re: Ref All Home - problem
« Reply #10 on: September 04, 2015, 11:07:50 AM »
I have just changed plugin(I had to separate limit switches from Home sewitches), and homing works fine but when I hit limit switch, push RESET and try move any axis a message shows: Jog function can't be enabled while homing, probing or dwell.
Best Regards
Amnon
« Reply #11 on: September 25, 2015, 05:08:58 AM »
We have the same problem. When I press Ref button, machine moves to limit switch and stops. It won't move back from limit switch and it doesn't reset machine coordinates as well. We are using official Mach3. Also I can't move machine manually after referencing, because the "jog function can't be enabled while homing, probing or dwell" message is displayed.
« Last Edit: September 25, 2015, 05:13:31 AM by teett »
Offline amnon
  •  40 40
« Reply #12 on: September 27, 2015, 08:38:43 AM »
Problem solved.
- your limit switches have to be NO
- separate limit switches from Home sewitches
Best Regards
Amnon
