Hello Guest it is November 22, 2026, 03:14:40 PM
Author Topic: Shuttle pro plugin (Mach4 version 2660)  (Read 12843 times)
Offline Pedio
  •  200 200
« on: August 30, 2015, 12:59:24 PM »
The new version of mach4 (Mach4 mill screen set) cause the center wheel on the Shuttle Pro plug in to move at a very rapid rate. Is there any way to control this? The previous version of Mach (2580) had this moving at a very slow rate. I would use the outer wheel to get close and then the center wheel to fine tune. I have tried:
  • changing the rapid rate slider
  • Using the old shuttlepro plug in from 2580
  • While in the shuttlepro programing mode moving the center wheel (this does not bring up the programming window for a button)
Thanks for any help / thoughts,
Peter
« Last Edit: August 30, 2015, 01:01:07 PM by Pedio »
Re: Shuttle pro plugin (Mach4 version 2660)
« Reply #1 on: August 31, 2015, 04:02:34 AM »
What is your incremental jog step size set at?
Offline Pedio
  •  200 200
« Reply #2 on: August 31, 2015, 08:46:28 AM »
Not sure where I find the "incremental jog step size". Is it this table? If it is which one?
The only other place I know that controls the speed of the axis movement is on the motor set up tab. You can slow it down with the jog % slider on the screen set.
Thanks for the help,
Peter
« Reply #3 on: September 03, 2015, 09:38:32 PM »
Yes, all of them.
From the operation manual:
2.2.4 Jogging Tab
The jogging tab, figure 2-20, displays controls for jogging the machine’s axes and changing the jog mode.
Figure 2-20: Jogging Tab
 Operator Control Selection: These are the tab markers. Select the desired tab by clicking on its name.
 Jog Buttons: Buttons to jog X, Y, Z and A axes.
 Cycle Incremental Jog Distance: In incremental jog mode each press of an axis jog button will move the machine on a specified distance, this button cycles through the distances defined in the general configuration. The current step distance in shown in the adjacent DRO.
 Toggle Jog Mode: Toggles between continuous and incremental jog modes.
 Jog Rate: Sets the velocity for continuous jog as a percentage of the machine’s max velocity.
 Toggle Keyboard Jog: Turns on/off the ability to jog using the keyboard.
However, it could also be a setting in the shuttle pro plugin. Or a function of one of the shuttle pros buttons to alter the step size. I have only played with the shuttle pro briefly though so cant say for sure.
« Last Edit: September 03, 2015, 09:41:14 PM by Chaoticone »
Offline Pedio
  •  200 200
« Reply #4 on: September 09, 2015, 02:25:12 PM »
Thanks - that fixed it.
