Hello Guest it is September 06, 2026, 04:36:22 AM
Author Topic: "SmartPath" or Waterjet Speed ramping based on geometry question??  (Read 9648 times)
It looks like Mach will do this but could someone verify: can Mach 3 do waterjet ramping based on geometry?
Thanks so much,
AKFALAR
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: "SmartPath" or Waterjet Speed ramping based on geometry question??
« Reply #1 on: May 02, 2007, 03:41:05 PM »
There is no set function for doing this, but it can be done with the accel/decel, by setting this to ramp up and down at a slow rate it is possible.
Graham.
« Reply #2 on: May 02, 2007, 07:21:52 PM »
Our current CAMsoft setup looks ahead for corners or circles of a tight diameter and based on the angular criteria it slows to accomodate.  I saw someone else talking about look ahead functionality.  Could you elaborate on this?
Thank you very much,
AKFALAR
« Reply #3 on: May 02, 2007, 10:27:43 PM »
We do that in the LazyCam for Plasma in circles ... and we could add it for small Arcs.
You could add that to the Galil plugin if you like...
www.newfangledsolutions.com
www.machsupport.com
