Hello
Guest
it is
October 20, 2026, 08:41:33 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
"SmartPath" or Waterjet Speed ramping based on geometry question??
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: "SmartPath" or Waterjet Speed ramping based on geometry question?? (Read 9845 times)
akfalar
3
on:
May 02, 2007, 03:11:54 PM »
It looks like Mach will do this but could someone verify: can Mach 3 do waterjet ramping based on geometry?
Thanks so much,
AKFALAR
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: "SmartPath" or Waterjet Speed ramping based on geometry question??
Reply #1 on:
May 02, 2007, 03:41:05 PM »
There is no set function for doing this, but it can be done with the accel/decel, by setting this to ramp up and down at a slow rate it is possible.
Graham.
Logged
akfalar
3
Reply #2 on:
May 02, 2007, 07:21:52 PM »
Our current CAMsoft setup looks ahead for corners or circles of a tight diameter and based on the angular criteria it slows to accomodate. I saw someone else talking about look ahead functionality. Could you elaborate on this?
Thank you very much,
AKFALAR
Logged
Brian Barker
3,860
Reply #3 on:
May 02, 2007, 10:27:43 PM »
We do that in the LazyCam for Plasma in circles ... and we could add it for small Arcs.
You could add that to the Galil plugin if you like...
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
