Hello
Guest
it is
November 23, 2026, 12:25:55 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
GENERAL SETUP PROBLEM
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: GENERAL SETUP PROBLEM (Read 7839 times)
markstk57
12
on:
August 11, 2015, 04:29:17 PM »
I am still a newbie but learning fast. I have a problem. I use a dxf file in LazyCam and produce TAP file. The dimensions are accurate and show in Mach3 as x and y. So a 9"x9" part when I cut it comes out as 1.675"x1.675" Suggestions.
Re: GENERAL SETUP PROBLEM
Reply #1 on:
August 11, 2015, 09:05:18 PM »
Post the dxf file.
Also post the .LCAM file.
Note that there is a Lazycam Manual and you should read it.
Print
Pages:
1
Go Up
« previous
next »
