Hello Guest it is November 12, 2026, 05:46:44 PM
Author Topic: GENERAL SETUP PROBLEM  (Read 7793 times)
« on: August 11, 2015, 04:29:17 PM »
I am still a newbie but learning fast.  I have a problem.  I use a dxf file in LazyCam and produce TAP file.  The dimensions are accurate and show in Mach3 as x and y.  So a 9"x9" part when I cut it comes out as 1.675"x1.675"  Suggestions.
Re: GENERAL SETUP PROBLEM
« Reply #1 on: August 11, 2015, 09:05:18 PM »
Post the dxf file.
Also post the .LCAM file.
Note that there is a Lazycam Manual and you should read it.
