Hello Guest it is November 13, 2026, 10:00:39 PM
Author Topic: Mach 3 Froze in Middle of Cycle  (Read 9364 times)
« on: July 26, 2015, 02:47:29 PM »
Afternoon all,
Hoping I can get some help, the other day, while in the middle of a program, Mach 3 froze on me (first time).  Spindle shut down and all axis stopped, likely due to the safety charge pump.  Spindle still showed 1,600rpms in Mach, but no variations, no X or Y movement, etc.  I had to close Mach via Task Manager for it to work again.  Keep in mind, I've ran several programs in the past without this ever happening.
I have a G0704 that I converted using the following:
BD Tools Motor Mounts
KL-5056D X & Y Stepper Drivers
KL-8070D Z Stepper Driver
NEMA 23 570 oz/in X & Y Steppers
NEMA 34 906 oz/in Z Stepper
CNC4PC C11 BOB
CNC4PC C3 Index Pulse Card
5v/10A PSU
12v/5A PSU
24V/5A PSU
48V/12.5A PSU
Desktop is a Dell OptiPlex 755 with the following specs:
Intel Core 2 Duo Processor 2.93GHz
Microsoft Windows 7 Professional 32-bit
2GB RAM
160GB Hard Drive
Anyone have any idea what may have caused this, have you ever had the same happen in the past?  Any idea what I can do to prevent it from happening again?
Wasn't a critical part, was just testing engraving for the first time.   Computer was wiped clean prior to installing Mach.
Zach
Re: Mach 3 Froze in Middle of Cycle
« Reply #1 on: July 26, 2015, 02:58:50 PM »
First thing to establish are you using the free demo version of Mach as it stop after 500 lines of programming
« Reply #2 on: July 26, 2015, 03:07:49 PM »
Negative, paid for and licensed version, plus I was online 72 of the code.
Zach
« Reply #3 on: July 26, 2015, 03:10:24 PM »
Do you have teh watchdog active ? IF SO turn it off and save then reopen.
