Mach Discussion => General Mach Discussion => Topic started by: zach540 on July 26, 2015, 03:47:29 PM
Afternoon all,
Hoping I can get some help, the other day, while in the middle of a program, Mach 3 froze on me (first time). Spindle shut down and all axis stopped, likely due to the safety charge pump. Spindle still showed 1,600rpms in Mach, but no variations, no X or Y movement, etc. I had to close Mach via Task Manager for it to work again. Keep in mind, I've ran several programs in the past without this ever happening.
I have a G0704 that I converted using the following:
BD Tools Motor Mounts
KL-5056D X & Y Stepper Drivers
KL-8070D Z Stepper Driver
NEMA 23 570 oz/in X & Y Steppers
NEMA 34 906 oz/in Z Stepper
CNC4PC C11 BOB
CNC4PC C3 Index Pulse Card
5v/10A PSU
12v/5A PSU
24V/5A PSU
48V/12.5A PSU
Desktop is a Dell OptiPlex 755 with the following specs:
Intel Core 2 Duo Processor 2.93GHz
Microsoft Windows 7 Professional 32-bit
2GB RAM
160GB Hard Drive
Anyone have any idea what may have caused this, have you ever had the same happen in the past? Any idea what I can do to prevent it from happening again?
Wasn't a critical part, was just testing engraving for the first time. Computer was wiped clean prior to installing Mach.
Zach
First thing to establish are you using the free demo version of Mach as it stop after 500 lines of programming
Negative, paid for and licensed version, plus I was online 72 of the code.
Zach
Do you have teh watchdog active ? IF SO turn it off and save then reopen.
