Hello Guest it is November 22, 2026, 07:11:03 AM
Author Topic: Startup and shutdown sequence  (Read 10134 times)
« on: June 26, 2015, 01:19:59 PM »
Hi,  just wanted to know what the correct startup and shutdown sequence is.  I am using uc-100 controller.  Do i turn machine on then mach3 for startup and then for shutdown turn off mach3 and then machine?
Re: Startup and shutdown sequence
« Reply #1 on: June 26, 2015, 03:26:36 PM »
It doesn't matter in my opinion. I don't know anything about the uc-100.
« Reply #2 on: June 26, 2015, 07:42:19 PM »
Imo, the machine should not be powered up until Mach3 is running. And the machine should be powered off before Mach3 is closed.
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: June 28, 2015, 08:25:37 AM »
I start up with the E-stop pressed, just in case a signal fires the plasma torch unexpectedly.
I generally just turn everything on and off but the E-Stop is always in before shutdown and startup.
