Hello
Guest
it is
November 22, 2026, 07:09:57 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Startup and shutdown sequence
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Startup and shutdown sequence (Read 10130 times)
Programinator
16
on:
June 26, 2015, 01:19:59 PM »
Hi, just wanted to know what the correct startup and shutdown sequence is. I am using uc-100 controller. Do i turn machine on then mach3 for startup and then for shutdown turn off mach3 and then machine?
Logged
Re: Startup and shutdown sequence
Reply #1 on:
June 26, 2015, 03:26:36 PM »
It doesn't matter in my opinion. I don't know anything about the uc-100.
Logged
ger21
6,295
Reply #2 on:
June 26, 2015, 07:42:19 PM »
Imo, the machine should not be powered up until Mach3 is running. And the machine should be powered off before Mach3 is closed.
Logged
Davek0974
2,606
Reply #3 on:
June 28, 2015, 08:25:37 AM »
I start up with the E-stop pressed, just in case a signal fires the plasma torch unexpectedly.
I generally just turn everything on and off but the E-Stop is always in before shutdown and startup.
Logged
Print
Pages:
1
Go Up
« previous
next »
