Hello Guest it is November 13, 2026, 11:49:12 AM
Author Topic: G0 Feedrate is not on maximum  (Read 12911 times)
« on: June 16, 2015, 11:34:46 AM »
Hello
I have one strange problem with G0 feedrate.
Maximum speed displacements in "Motor Tuning" is set to 8000 mm / min. and it is actually that when moving machine with the arrow keys.
Even when I write to the MDI, for example:
G01 X200 F6000
the moving is correct  - fast.
However, if I write:
 G0 X200,
the moving is reduced to 1000mm/min. (also in the window "feedrate")
Also from G-code  G0 is slow, just 1000 mm / min.
I checked all the possible settings ....... please if anyone can help me before I go crazy.
Re: G0 Feedrate is not on maximum
« Reply #1 on: June 16, 2015, 02:34:32 PM »
Is your rapid override set lower than 100%?
« Reply #2 on: June 16, 2015, 02:51:04 PM »
No, is set on 100%
Rapid override is working properly.
F is always 1000 (when caled G0)
FRO is changing if I change rapid override but always   1000 * rapid override (%)
« Reply #3 on: June 22, 2015, 12:22:22 PM »
I'm still not able to find the cause of the slow moving ... unfortunately  :( ??? :-[
« Reply #4 on: August 31, 2015, 02:47:04 AM »
Hello
Anyone with the same problems?
Any suggestions to resolve the problem?
Thanx!
« Reply #5 on: September 01, 2015, 04:59:01 PM »
Attach your xml and I will see if I can find the problem.
