Mach Discussion => General Mach Discussion => Topic started by: MojsterMiha on June 16, 2015, 12:34:46 PM
Hello
I have one strange problem with G0 feedrate.
Maximum speed displacements in "Motor Tuning" is set to 8000 mm / min. and it is actually that when moving machine with the arrow keys.
Even when I write to the MDI, for example:
G01 X200 F6000
the moving is correct - fast.
However, if I write:
G0 X200,
the moving is reduced to 1000mm/min. (also in the window "feedrate")
Also from G-code G0 is slow, just 1000 mm / min.
I checked all the possible settings ....... please if anyone can help me before I go crazy.
Is your rapid override set lower than 100%?
No, is set on 100%
Rapid override is working properly.
F is always 1000 (when caled G0)
FRO is changing if I change rapid override but always 1000 * rapid override (%)
I'm still not able to find the cause of the slow moving ... unfortunately :( ??? :-[
Hello
Anyone with the same problems?
Any suggestions to resolve the problem?
Thanx!
Attach your xml and I will see if I can find the problem.
