Hello Guest it is November 24, 2026, 01:01:38 PM
Author Topic: feedrate changing after spindle stop part 2  (Read 34364 times)
Re: feedrate changing after spindle stop part 2
« Reply #20 on: June 19, 2015, 10:17:32 AM »
Unless you include an F statement in the init string then Mach3 does NOT have a default feedrate .
« Reply #21 on: June 21, 2015, 07:15:39 AM »
thanks BR540- seems that is what is causing my concern
the configuration is set a 25000 and when i look at the diags the reported speed is 23800( or thereabouts)
could this be the cause ?
This whole problem has led to me doing quite a lot of research and for anyone else who
may be interested in the topis take a look at  "Google Mach3 feedrate " ther are many posts about the same thing.
thank you all very much - i think this answers my queries.
regards from South africa
« Reply #22 on: June 21, 2015, 07:22:28 AM »
Br549-- a last question
I am not calling css in the code but the initstring is using "constant velocity"
Is this the same thing - any wat i have changed it to exact stop to see what happens
regards
fred
« Reply #23 on: July 05, 2015, 07:23:02 PM »
I don't know, but there seems to be something lurking in the depths of the code ... a few days ago, my feedrate changed suddenly from 70 mm/min to 1000 mm/min and couldn't be changed with the f word. A reboot fixed that, but not the tool  >:(
If that's now good or bad, that this was a one-of-a-kind-accident ...?
« Reply #24 on: July 06, 2015, 02:21:26 AM »
Hello Stephan--
When I changed to f per minute the problem went away and I was able to
finish the job i was on .
Then I had a gearbox failure so I havent used the machine for the last week
or so.
Please keep us informed
regards
fred
