Hello
Guest
it is
November 15, 2026, 06:10:32 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach3 under Vista
Mach3 under win10
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
Go Down
Author
Topic: Mach3 under win10 (Read 377864 times)
joeaverage
7,663
Re: Mach3 under win10
Reply #70 on:
October 19, 2017, 05:02:28 AM »
I've just re-read the manual, what there is of it, and I think my previous post is wrong. It says the 12-24V supply is optional.
Can you post your xml file, may be we can spot a problem in the setup.
Dcj
11
Reply #71 on:
October 19, 2017, 05:37:37 AM »
As I understand the 12-24V power is required only if you are going to have limit switches and an E stop button. I have a 15V power supply attached to the board but have not been able to get a signal to Mach3 when I close the one limit switch attached to the board when looking at the inputs screen.
Not sure what you mean for me to post my xml file. Is it the Mach 3 setup file?
Dale
Dcj
11
Reply #72 on:
October 19, 2017, 06:43:56 AM »
If I'm using usb with a UC100 motion controller, do I have to pick a port like when using a parallel port?
joeaverage
7,663
Reply #73 on:
October 19, 2017, 07:18:54 AM »
Hi Dale,
even if you don't want limit switches you will still need an Estop therefore the 12-24V supply is required.
Pick port 1 although the UC100 makes the selection a moot point.
Yes, an .xml file is all the Mach setup data. On the lower right of the Mach screen is the current profile name.
Find it in your Mach3 folder and make a copy name dale.xml. Post the copy.
ger21
6,295
Reply #74 on:
October 19, 2017, 07:33:27 AM »
You need to assign port 1 when setting up the pin numbers, for all of your inputs and outputs.
Dcj
11
Reply #75 on:
October 19, 2017, 09:00:59 AM »
Putting in port 1 solved the problem. Motor running fine. I'm going to hook up the other motors and switches. Thanks for all the help. This forum is great. Dale
sparky03
3
Reply #76 on:
November 18, 2017, 06:29:28 PM »
Are we ever going to have a version of Mach that joins the rest of us in the 21 century?
ger21
6,295
Reply #77 on:
November 18, 2017, 06:48:41 PM »
If you want to use a printer port with Windows 10, then no.
Otherwise, Mach3 and Mach4 run fine in Windows 10.
Keep in mind that development of Mach3 stopped about 5 years ago, so you'll never see another version of it.
sparky03
3
Reply #78 on:
November 18, 2017, 08:05:33 PM »
Will using a USB motion controller for Mach3 work in Windows 10 32 bit or 64 bit?
Last Edit: November 18, 2017, 08:09:46 PM by sparky03
ger21
6,295
Reply #79 on:
November 18, 2017, 08:10:54 PM »
If you use a USB or ethernet motion controller from a reputable company, you shouldn't have any issues. My preference is CNC Drive controllers, as they have excellent support, and are constantly updating their firmware.
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
Go Up
« previous
next »
