Hello Guest it is October 24, 2026, 03:31:53 PM
Author Topic: Support M10/M11 commands  (Read 32509 times)
« on: May 06, 2015, 04:27:19 AM »
Who knows if it supports M10/M11 and EXP0/EXP1 command?
I use CSMIO/IP-M and assign Output#5 signal to PORT10 PIN1. But command M10 (ActivateSignal(11)) or M11(DeActivateSignal(11)) does not work. OUTPUT1 change state if I select/deselect "ActiveLow", but not respond to command.
Thanks!!!
--Andrew
Offline TPS
  •  2,627 2,627
Re: Support M10/M11 commands
« Reply #1 on: May 06, 2015, 04:49:06 AM »
M10/M11 are used with Parameter
M11P5 means output ON
M10P5 means output OFF
nothing additional needed in macro M10.M1S and M11.M1S.
Thomas
« Reply #2 on: May 06, 2015, 04:50:27 AM »
Hi thanks for the fast reply!
Can I use E5P1 and E5P0 command for this?
--Andrew
Offline TPS
  •  2,627 2,627
« Reply #3 on: May 06, 2015, 04:54:02 AM »
sorry not idea what E5P1 and E5P0 should do.
Thomas
« Reply #4 on: May 06, 2015, 04:56:27 AM »
OK, In any case Thanks a lot!
I use command E5P0 and E5P1 for THC ON/OFF control from G-Code. This commands is no issue pause in motion.
And M10/M11 too, I hope.
--Andrew
« Reply #5 on: May 10, 2015, 01:33:44 AM »
Hi Thomas!
M11P5 and M10P5 is not work for me. I am assign for Mach3 Output#5  Port10 pin 4 for Output4 of the CSMIO.
Output state in the CSMIO IO diagnostic window change if I check/uncheck ActiveLow. But from G-Code M11P5 /M10P5 not changing of the state.
Can you check it's?
Thanks!!!
--Andrew
Offline TPS
  •  2,627 2,627
« Reply #6 on: May 10, 2015, 06:58:11 AM »
it is working here (PP driver).
only thing i did is in CONFIG -> ports&pins -> mill option -> allow THC functions when not enabled.
Thomas
« Reply #7 on: May 10, 2015, 01:18:36 PM »
Thomas, this is CS-Lab thread and I think you use CSMIO. Yes in PP all work fine.
--Andrew
« Reply #8 on: May 10, 2015, 01:57:58 PM »
I send the message to CSMIO support about this question.
My THC controller is not use internal Mach3 THC  function, but I need this signal for control THC ON/OFF during execution of the G-Code.
« Last Edit: May 10, 2015, 01:59:41 PM by shad71 »
--Andrew
Offline TPS
  •  2,627 2,627
« Reply #9 on: May 11, 2015, 01:26:20 AM »
Hi Andrew,
here in the CSMIO tutorial about THC
http://www.cs-lab.eu/en/index.php?m=article&s=main&aid=146&uinfo=THC_Analog_function
they are talking about to use M3/M5 for THC ON/OFF
my testmachine in office is PP port, i will test this evening on the CSMIO machine.
Thomas
